Hi Rob,
I've developed many of the performance curves utilized by BEopt EnergyPlus for central, variable-speed air conditioners and mini-split heat pumps. However before I can help answer your question, I need to know what does the data look like for the unit you're trying to model. Do you have expanded performance data at specific speeds?
