can you please tell which software are you using? is it DesignBuilder or E+, because in DB if you use simple HVAC mode or Compact mode than the result is listed in District cooling as you are getting. Also in EP if you use an ideal Load Air system than also you will get the same results in District cooling (as Mr.Eric has informed).
