Disclaimer: I think that getting the controls for this to work will be tricky, and I haven't modeled this configuration myself, but here's where I would start. You might need a setpoint manager on the outlet side of the Heat Exchanger on the Radiant Loop depending on the control options you choose.
Chilled Water Loop with Heat Exchanger on return side of coils
Radiant Loop fed by Heat Exchanger
