Looks like in a number of cases the OpenStudio.idd for OS:ScheduleTypeLimits is out of sync with the EnergyPlus.idd for TypeLimits.
I'll investigate why this is the case, but it is problematic that we are generating idf, that while they run fine, other applications including our own find it invalid.
Here is a list of valid Unit Types for EnergyPlus TypeLimits
\key Dimensionless
\key Temperature
\key DeltaTemperature
\key PrecipitationRate
\key Angle
\key ConvectionCoefficient
\key ActivityLevel
\key Velocity
\key Capacity
\key Power
\key Availability
\key Percent
\key Control
\key Mode
Here is a list of valid Unit Types for OS:ScheduleTypeLimits. * added by ones that don't also exist in EnergyPlus
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key ClothingInsulation *
\key Velocity
\key RotationsPerMinute *
\key VolumetricFlowRate *
\key MassFlowRate *
\key Capacity
\key Power
\key Pressure *
\key SolarEnergy *
\key Availability
\key Percent
\key ControlMode * (maybe forward translates to "Control", I haven't tested)
\key LinearPowerDensity *
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key Capacity
\key Power
\key Availability
\key Percent
\key Control
\key Mode
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key MassFlowRate *
\key Capacity
\key Power
\key Pressure *
\key SolarEnergy *
\key Availability
\key Percent
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key Capacity
\key Power
\key Availability
\key Percent
\key Control
\key Mode
Here is a list of valid Unit Types for OS:ScheduleTypeLimits. * added by ones that don't also exist in EnergyPlusOS:ScheduleTypeLimits
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key MassFlowRate *
\key Capacity
\key Power
\key Pressure *
\key SolarEnergy *
\key Availability
\key Percent
Here is a list of valid Unit Types for EnergyPlus TypeLimitsTypeLimits
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key Capacity
\key Power
\key Availability
\key Percent
\key Control
\key Mode
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key Capacity
\key Power
\key Availability
\key Percent
\key Control
\key Mode
\key Dimensionless
\key Temperature
\key Angle
\key ActivityLevel
\key Velocity
\key MassFlowRate *
\key Capacity
\key Power
\key Pressure *
\key SolarEnergy *
\key Availability
\key Percent
