You can do both with one simulation, just adding 2 SizingPeriod:DesignDay objects, one for winter and one for summer. The temperature should be set in the Maximum Dry Bulb Temperature field. If the "Daily Dry-bulb Temperature Range" is set to 0, the temperature will be constant throughout the whole day (otherwise it will be sinusoidal). For solar radiation, you should set Sky clearness to 0 for winter and to 1 for summer (be sure that the solar model indicator is ASHRAEClearSky). However, in the Input Output Reference you will find all the information you need.
