What is your HeatExchanger:FluidToFluid Control Type? Make sure you use something like HeatingSetpointModulated (any of the heating ones).
Check the resulting IDF too, the HX currently ends up by default on a PlantEquimentOperation:Uncontrolled, while ideally it would end up first in line on the PlantEquipmentOperation:HeatingLoad (FYI, this is going to be the case now that my PR #2851 got merged in), but this isn't necessarily mandatory.
Start with he control type, if it still doesn't work, I'd try to change the PlantEquipmentOperation manually, using the ruby bindings: create a PlantEquimentOperation:HeatingLoad, put the HX then the water heater, and set that to the plant Loop. Set the PlantLoop's Load Distribution scheme to SequentialLoad (make sure you do end up with a PlantEquipmentList that has the HX first, then the WaterHeater:Mixed)
Start with he control type, if it still doesn't work, I'd try to change the PlantEquipmentOperation manually, using the ruby bindings: create bindings (create a PlantEquimentOperation:HeatingLoad, put the HX then the water heater, and set that to the plant Loop. Set the PlantLoop's Load Distribution scheme to SequentialLoad (make sure you do end up with a PlantEquipmentList that has the HX first, then the WaterHeater:Mixed)Loop).
Start with he control type, if it still doesn't work, I'd try to change the PlantEquipmentOperation manually, using the ruby bindings (create a PlantEquimentOperation:HeatingLoad, put the HX then the water heater, and set that to the plant Loop).
