You could find your Curve by getting all the curves in the model and then finding the one named "Curve".
mycurves = model.getCurveBiquadratics
theCurve=[]
mycurves .each do |mcurve|
if mcurve.name.to_s == 'Curve'
theCurve = mcurve
break
end
end
Then you can use the methods listed here to change the Curve.
Alternatively, you could stay with the boost code you used and once you done with the first curve delete it using .remove
and rename the new one to whatever you need.
theCurve=[]
if mcurve.name.to_s mcurve.name == 'Curve'
theCurve = mcurve
break
end
end
"Curve".
theCurve=[]
if mcurve.name == 'Curve'
theCurve = mcurve
break
end
end
and rename the new one to whatever you need.mcurve
