The two options cannot be achieved with expression input for glazings because the expression input cannot make the value of keywords vary hourly. But in eQuest, glazing can be switched based on outside dry-bulb temperature, daylight illuminance, space load, intensity of solar radiation incident on the glazing and so on. It can be set in the blind/drapes-switching tab.
The two options cannot be achieved with expression input for glazings because the expression input cannot make the value of keywords vary hourly. with hour. But in eQuest, glazing can be switched based on outside outsider dry-bulb temperature, daylight illuminance, space load, intensity load,intensity of solar radiation incident on the glazing and so on. It can be set in the blind/drapes-switching tab.
The two options cannot be achieved can not achieve with expression input for glazings because glaze.beacause the expression input cannot can not make the value of keywords vary very with hour. But hour.But in eQuest, glazing eQuest,glazing can be switched based on outsider dry-bulb temperature, daylight illuminance, space load,intensity of solar sloar radiation incident on the glazing and so on. It on .It can be set in the blind/drapes-switching blind/draps-switching tab.
