There is no limit, aside from what's practical... If you planned on using one rule for every hour of year, I'd strongly advise to not do that and use Schedule:FixedInterval
or Schedule:VariableInterval
(or Schedule:File
once it gets implemented). See Can you load Schedule:File in OpenStudio?
In OS, the ScheduleRule
is the one that references the ScheduleRuleset
, so there's no limitation possible anyways.
If you want to convince yourself, use the ruby bindings in a terminal, type the following code, and go make yourself a coffee while it finishes (it should take like 10 minutes I think... I just did it for 1000 times while writing this).
m = OpenStudio::Model::Model.new
s = OpenStudio::Model::ScheduleRuleset.new(m)
10000.times.each do |i|
puts i
s_rule = OpenStudio::Model::ScheduleRule.new(s)
end
(or Schedule:File
once it gets implemented). See Can you load Schedule:File in OpenStudio?implemented).
puts i
end
