Without more detail about the outputs you're interested in it's hard to provide a specific answer.
However, the LEED Summary section of the HTML output lists the electrical and thermal EUI by end use in Tables EAp2-17. In the OpenStudio application these can be found here:
Results Summary > Reports > EnergyPlus Results > Table of Contents > LEED Summary
Or by navigating to the HTML output file:
osm file directory > run > EnergyPlus > eplustbl.htm or eplustbl.csv
However, the LEED Summary of the HTML output lists the electrical and thermal EUI by end use in Tables EAp2-17. In OpenStudio these can be found here:
Results Summary > EnergyPlus Results > Table of Contents > LEED Summary
