If you follow the advise from this post you can manually install the OpenStudio SketchUp Plugin for SketchUp 2018. SketchUp 2018 has the same internal Ruby version as SketchUP 2017. As a note there is no SketchUp Make with 2018. That is being replaced with a web based SketchUp that doesn't support Ruby plugins. You can also continue to use OpenStudio with SketchUp 2017.
If you follow the advise from this post you can manually install the OpenStudio SketchUp Plugin for SketchUp 2018. SketchUp 2018 has the same internal Ruby version as SketchUP 2017. As a note there is no SketchUp Make with 2018. That is being replaced with a web based SketchUp that doesn't support Ruby plugins. You can also continue to use OpenStudio with SketchUp 2017.2017.
A future installer will support direct installation of the plugin for SketchUp 2018, I don't know yet if this will be in the December release.
