A DX cooling coil removes both sensible (temperature) and latent (moisture) energy from the air stream. Water cooling coils also have this same property. When using a cooling coil in your simulation roughly 25% of the energy transfer will be moisture. So the result will be that the indoors are dryer than outdoors.
