Other than post processing I'm not sure how to actually do this in EP or OS, but here are some thoughts.
Snowmelt
- Write an EnergyPlus Measure to add a GroundHeatExchanger:Surface object. The Input Output Reference specifically mentions snowmelt in the description.
Outdoor Pool
Use a WaterHeater:Mixed object to approximate the pool
Construct a zone to approximate a pool with a window to allow for solar gains
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method. The UI on that site is atrocious IMO so I wasn't able to actually find the attachment there, but hopefully others will have better luck.
For reporting you may have to use/write a measure for a meter or variable output and then post process.
Let us know what you come up with.
Snowmelt
Outdoor Pool
Use a
WaterHeater:Mixed object toapproximate the poolapproximateConstruct a zone to approximate a pool with a window to allow for solar gains
TheThat UI on that site is atrocious IMO so I wasn't able to actually find the attachment there, but hopefully others will have better luck.
Snowmelt
Outdoor Pool
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method. That
UIUX on that site is atrocious IMO so I wasn't able to actually find the attachment there, but hopefully others will have better luck.
Snowmelt
Outdoor Pool
method. That UX on that site is atrocious IMO somethod, but for the life of me I wasn't able to actually findthe attachment there, but hopefully others will have better luck.it.
Snowmelt
Outdoor Pool
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method, but for the life of me I wasn't able to actually find
it.it there.
