@mdahlhausen is right, you need to include an HVAC system in your proposed model so that the baseline system type can be determined. The proposed model's HVAC system doesn't actually have to work, it is just used to determine whether the baseline HVAC system should be gas or electric. Also, like the error message says, you can re-run the measure with the debug checkbox turned on to see more details.
