You can use system or dos function to call RunEPlus.bat located in EnergyPlus directory. There are two ways rnning energyplus:
1. Runging RunEPlus.bat batch file
For example:
dos('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without idf extension) in(weather file without epw extension)')
system('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without idf extension) in(weather file without epw extension)')
2. Runing energyplus.exe
For example:
system('C:\YOUR_ENERGYPLUS_INSTALLATION_FOLDER\EnergyPlus.exe -w weather_file.epw idf_file.idf')
where -w represents the weather file option. Without "-w" you only get a sizing run. Here are more details (https://github.com/NREL/EnergyPlus/bl...)
For example:
For example:
where -w represents the weather file option. Without "-w" you only get a sizing run. Here are more details (https://github.com/NREL/EnergyPlus/bl...)) Please change your answer.
For example:
For example:
where -w represents the weather file option. Without "-w" you only get a sizing run. Here are more details (https://github.com/NREL/EnergyPlus/bl...) (https://github.com/NREL/EnergyPlus/bl...) Please change your answer.
For example:
extension)') or<br> system('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without idf extension) in(weather file without epwextension)')extension)')
For example:
where -w represents the weather file option. Without "-w" you only get a sizing run. Here are more details (https://github.com/NREL/EnergyPlus/bl...) Please change your answer.
For example:
dos('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without idf extension) in(weather file without epw extension)') or<br> system('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without idf extension) in(weather file without epw extension)')
For example:
For example:
For example:
For example:
dos('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without excluding idf extension) in(weather file without epw extension)') in.epw') or
system('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat in(idf file name without excluding idf extension) in(weather file without epw extension)')in.epw')
For example:
dos('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat dos('D:\RunEPlus.bat in(idf file name excluding idf extension) in.epw') or
system('D:\Your_EnergyPlus_installation_folder\RunEPlus.bat system('D:\RunEPlus.bat in(idf file name excluding idf extension) in.epw')
For example:example:
oror
For example:
