Here's what's going on:
In the code, it assumes that either:
- The pump flow rate was autosized and the autosized rated flow rate is available in the SQL file for this pump, which means that a sizing run has been done already.
- The pump flow rate was hard sized.
The code needs to be modified to throw a better, more explanatory error when neither of these conditions are met.
You can run a sizing run using OpenStudio-Standards in your measure via:
model.runSizingRun()
