Hi thanks for sharing the link to that fanpower calculator. I have a question, It seems to work well to generate the system fan power but when it comes to the energyplus - enduse output the demand (kW) does not match the system fanpower calculated from 90.1. Is it supposed to match? I can see in the equipment outputs the fan-power matches the calculator but not in the enduse. any thoughts?
