If you plan on running an EnergyPlus simulation for only a few months to overlap with the time when your temperature data was measured, then you want to change the begin / end input fields of your RunPeriod
object accordingly. After that, you can create "fake data" (i.e. manually enter zeros) for the remainder of the year in your schedule file so that EnergyPlus can read it correctly.
