I've done this in a fairly brute force way with Python. I'm sure there are better ways to do it. Here's the outline:
- Use the
globmodule to find all the IDFs to transition, make sure to get the full absolute paths. - Use
os.chdirto change directories into the directory that contains the transition executables. - Loop over the IDF files with a nested loop that loops over the transition executables that are needed.
Part of the reason that I did it this way was that I wanted the intermediate versions. If you don't, then this might not be the best approach for you.
