Yes. Use the run period selectors on the simulation settings tab shown here:
The simulation will pick the correct weather from the EPW file. Design days are used to size equipment for extreme conditions - that's distinct from the days the simulation is being performed. I would recommend using the extreme days from the DDY file as opposed to sizing the system using the conditions on that single day you are simulating.
