It looks like there is a problem with using the design specification object in HVACTemplate:Zone:VAV. The design specification object name is not included in the Sizing:Zone object. Edit the *.expidf file using a text editor. Search for the Sizing:Zone objects and add the name of the DesignSpecification:OutdoorAir object in the correct field (field 10) . Then change the name of that file so it has the idf extension (e.g., MyFile.idf) and run the simulation. Or you could change the file name first and make this correction using the IDFEditor from EP-Launch.
Sizing:Zone,
  SPACE1-1,               !- Zone or ZoneList Name
  SupplyAirTemperature,   !- Zone Cooling Design Supply Air Temperature Input Method
  12.8,                   !- Zone Cooling Design Supply Air Temperature {C}
  11.11,                  !- Zone Cooling Design Supply Air Temperature Difference {delta C}
  SupplyAirTemperature,   !- Zone Heating Design Supply Air Temperature Input Method
  50.0,                   !- Zone Heating Design Supply Air Temperature {C}
  ,                       !- Zone Heating Design Supply Air Temperature Difference {delta C}
  0.008,                  !- Zone Cooling Design Supply Air Humidity Ratio {kg-H20/kg-air}
  0.008,                  !- Zone Heating Design Supply Air Humidity Ratio {kg-H2O/kg-air}
  Office_OA,                       !- Design Specification Outdoor Air Object Name
  ,                       !- Zone Heating Sizing Factor
  ,                       !- Zone Cooling Sizing Factor
  DesignDay,              !- Cooling Design Air Flow Method
  0,                      !- Cooling Design Air Flow Rate {m3/s}
  ,                       !- Cooling Minimum Air Flow per Zone Floor Area {m3/s-m2}
  ,                       !- Cooling Minimum Air Flow {m3/s}
  0,                      !- Cooling Minimum Air Flow Fraction {}
  DesignDay,              !- Heating Design Air Flow Method
  0,                      !- Heating Design Air Flow Rate {m3/s}
  ,                       !- Heating Maximum Air Flow per Zone Floor Area {m3/s-m2}
  ,                       !- Heating Maximum Air Flow {m3/s}
  0,                      !- Heating Maximum Air Flow Fraction {}
  ;                       !- Design Specification Zone Air Distribution Object Name
It looks like there is a problem with using the design specification object in HVACTemplate:Zone:VAV. The design specification object name is not included in the Sizing:Zone object. Edit the *.expidf file using a text editor. Search for the Sizing:Zone objects and add the name of the DesignSpecification:OutdoorAir object in the correct field (field 10) . Then change the name of that file so it has the idf extension (e.g., MyFile.idf) and run the simulation. Or you could change the file name first and make this correction using the IDFEditor from EP-Launch.IDFEditor.
Sizing:Zone,
It looks like there is a problem with using the design specification object in HVACTemplate:Zone:VAV. The design specification object name is not included in the Sizing:Zone object. Edit the *.expidf file using a text editor. Search for the Sizing:Zone objects and add the name of the DesignSpecification:OutdoorAir object in the correct field (field 10) . Then change the name of that file so it has the idf extension (e.g., MyFile.idf) and run the simulation. Or you could change the file name first and make this correction using the IDFEditor.simulation.
Sizing:Zone,
It looks like there is a problem with using the design specification object in HVACTemplate:Zone:VAV. The design specification object name is not included in the Sizing:Zone Sizing:Zone object. Edit the *.expidf file using a text editor. Search for the Sizing:Zone Sizing:Zone objects and add the name of the DesignSpecification:OutdoorAir DesignSpecification:OutdoorAir object in the correct field (field 10) . Then change the name of that file so it has the idf extension (e.g., MyFile.idf) and run the simulation.
Sizing:Zone,
It looks like there is a problem with using the design specification object in HVACTemplate:Zone:VAV. object. The design specification object name is not included in the Sizing:Zone object. Edit the *.expidf file using a text editor. Search for the Sizing:Zone objects and add the name of the DesignSpecification:OutdoorAir object in the correct field (field 10) . Then change the name of that file so it has the idf extension (e.g., MyFile.idf) and run the simulation.
Sizing:Zone,
It looks like there is a problem with using the design specification object. The design specification object name is not included in the Sizing:Zone object. Edit the *.expidf file using a text editor. Search for the Sizing:Zone objects and add the name of the DesignSpecification:OutdoorAir object in the correct field (field 10) . Then change the name of that file so it has the idf extension (e.g., MyFile.idf) and run the simulation.
Sizing:Zone,
Sizing:Zone,
