Update 2018/01/09 I heard back from IES on this and they found that there is an issue with chiller curves when using IP units. There is no issue if you are using SI units. For default curves in IP there is an incorrect conversion being applied which affects the visualization. This does not actually affect the simulation results. However, if you create a custom chiller curve in IP the conversion will affect results, so use SI when inputting a custom chiller curve.
Cnorm
is the result of the curve at the design conditions. For curves that do not result in "1" at the rated condition, this will "normalize" the curve for you. Though all of the default eQuest curves already equal "1" at rated conditions and don't need this (though if you are using design conditions it might).
The EIRrated curve is created using this equation:
EIRrated = EIRfPLR / PLR
Update 2018/01/09 I heard back from IES on this and they found that there is an issue with visualization of chiller curves when using IP units. There is no issue if you are using SI units. For default curves in IP there is an incorrect conversion being applied which affects the visualization. This does not actually affect the simulation results. However, if you create a custom chiller curve in IP the conversion will affect results, so use SI when inputting a custom chiller curve.
Cnorm
Update 2018/01/092017/12/14 I heard back from IES on this and they found that there is an issue with visualization of chiller curves when using IP units. There is no issue if you are using SI units. For default This issue is with the chiller curves in IP there is an incorrect conversion being applied which affects themselves, not just the visualization. This does not actually affect the simulation results. However, if visualization, so you create a custom chiller curve in IP the conversion will affect results, so should use SI when inputting a custom chiller curve.units to simulate chillers until the issue is resolved.
Cnorm
Update 2017/12/14Update I heard back from IES on this and they found that there is an issue with visualization of chiller curves when using IP units. There is no issue if you are using SI units. This It is unclear if this issue is with the chiller curves themselves, not just the visualization, so you should use SI units to simulate chillers until the issue is resolved.with visualization or if it is also with the curves themselves used in the simulation.
What IES says its using as curve coefficients for the generic hermetic centrifugal; vsd
chiller, it really isn't. It's actually using the same curves as eQuest uses for CentH2OVSD
. They are very similar, but with a couple of coefficients different (b & c only). For this particular curve (EIR-f-PL&dT
) the coefficients are:
Also, Cnorm
The EIRrated So when I use the eQuest curve coefficients, and with those Cnorm
isn't necessary, I get the correct curve, the same as IES is visualizing:
And this curve is created using this equation:by using this equation:
Update I heard back from IES on this and they found that there is an issue with visualization of chiller curves when using IP units. There is no issue if you are using SI units. It is unclear if this issue is just with visualization or if it is also with the curves themselves used in the simulation.
Also, Cnorm
is the result of the curve at the design conditions. For curves that do not result in "1" at the rated condition, this will "normalize" the curve for you. Though all of the eQuest curves already equal "1" at rated conditions and don't need this (though if you are using design conditions it might).
And this curve is created by using this equation:
Also, Cnorm
EIRrated [EIRfactor = EIRfPLR / PLR\frac{EIRfPLR}{PLR}]
Also, Cnorm
[EIRfactor = \frac{EIRfPLR}{PLR}]
Also, Cnorm
is the result of the curve at the design conditions. For curves that do not result in "1" at the rated design condition, this will "normalize" the curve for you. Though all of the eQuest curves already equal "1" at rated design conditions and don't need this (though if you are using design conditions it might).this.
