This is the model i am working on! When i changed the parameters of the gain to 0.001 and Ti=300, then the model seems to work better. I also used the P-Controller as you suggested, and the results are similar to the PI case. For the P-Controller k=0.01. My question is if those numbers seem reasonable or are too small.
