The directions you followed are for earlier versions of OpenStudio.
In OpenStudio v2.+, ruby comes installed with OpenStudio, and the ruby directory lives in the OpenStudio install. When you require 'openstudio'
, it seems like you are asking your C:\Ruby200-x64
install to access the openstudio
file located in your OpenStudio v2.+ install.
In OpenStudio v2.+, instead of adding require 'openstudio'
to the top of your ruby script and running ruby foo_script.rb
, you can just run openstudio foo_script.rb
, you can just run `openstudio foo_script.rb
