I don't know if this works also for you, but if you download the program elements (open-source). Here your have a link: http://bigladdersoftware.com/projects/elements/
With this program you can open epw. files. With the following link you can see the steps you have to take in order to get your results: http://bigladdersoftware.com/projects/elements/docs/user-guide/tutorial-create-from-scratch.html
This link might also help when you use Elements: https://unmethours.com/question/11948/elements-normal-solar-versus-direct-normal-radiation/
I don't know if this works also for you, works, but if you download the program elements (open-source). Here your have a link: http://bigladdersoftware.com/projects/elements/
With this program you can open epw. files. With Maybe the following link you can see program automatically devides the steps you have to take in order to get your results: http://bigladdersoftware.com/projects/elements/docs/user-guide/tutorial-create-from-scratch.htmlradiation into horizontal and normal radiation. It is worth a try.
