You can either lump them into one, or you can define 5 PV arrays (Generator:Photovoltaic) each with their own inverter.
Which one you choose depends on how detailed of a simulation you're doing. If you're using ELCD:Inverter:Simple, there's no point in going through the hassle of creating 5 arrays, I'd just lump them. If you use another type of inverters, then maybe it's worth the extra work.
If you choose to break them into 5, and they are currently in the same surface, you'll need to subdivise the surface into 5 too.
