Plug loads are not determined by 90.1 in the same way as LPD, so different valid templates may have different valid EPD values and breakdown. I wasn't able to quickly find a detailed list for the DOE prototype buildings, but Table. 3.3 of the Technical Support Document for ASHRAE AEDG: 50% Energy Savings Design for Medium Office Buildings has a Office Equipment Inventory list with a quantity and power value for each equipment type. The baseline office has 8.07 W/m^2 not too far off from the 7.64 you refer to.
Plug loads are not determined by 90.1 in the same way as LPD, so different valid templates may have different valid EPD values and breakdown. I wasn't able to quickly find a detailed list for the DOE prototype buildings, but Table. 3.3 of the Technical Support Document for ASHRAE AEDG: 50% Energy Savings Design for Medium Office Buildings has a Office Equipment Inventory list with a quantity and power value plug load each for each equipment type. office equipment. The baseline office has 8.07 W/m^2 not too far off from the 7.64 you refer to.
Plug loads are not determined by 90.1 in the same way as LPD, so different valid templates may have different valid EPD values and breakdown. I wasn't able to quickly find a detailed list quickly for the DOE prototype buildings, but Table. 3.3 of the Technical Support Document for ASHRAE AEDG: 50% Energy Savings Design for Medium Office Buildings has a Office Equipment Inventory list with a quantity and plug load each for office equipment. The baseline office has 8.07 W/m^2 not too far off from the 7.64 you refer to.
Plug loads are not determined by 90.1 in the same way as LPD, so different valid templates may have different valid EPD values and breakdown. I wasn't able to find a detailed list quickly for the DOE prototype buildings, but Table. 3.3 of the Technical Support Document for ASHRAE AEDG: 50% Energy Savings Design for Medium Office Buildings has a Office Equipment Inventory inventory list with a quantity and plug load each for office equipment. The baseline office has 8.07 W/m^2 not too far off from the 7.64 you refer to.
