Over the weekend and today, I ve tried multiple times to generate the FMU but I always get the same error.
*[fmiError]: test_file_FMU_fmu: fmiInitializeSlave: Could not create the input and weather file. Initialization of test_file_FMU_fmu failed. The following error was detected at time: 0 InitializeSlave failed The stack of functions is: test_file_FMU_fmu.fmi_Functions.fmiInitializeSlave test_file_FMU_fmu.fmi_Functions.fmiInitializeSlave( test_file_FMU_fmu1.fmi, test_file_FMU_fmu1.fmi_StartTime, test_file_FMU_fmu1.fmi_forceShutDownAtStopTime, test_file_FMU_fmu1.fmi_StopTime, test_file_FMU_fmu1.fmi_AParamsAndStart+test_file_FMU_fmu1.fmi_initInput0) Error: Failed to start model. Just to remind you that I am using EnergyPlusv8-6-0,EnergyPlusToFMUv2-0-2,Dymola 2017FD01. Is there any incompatibility between these versions?
I am not sure what is the source of the problem. Furthermore, the userGuide says that after the simulation a folder Output_EPExport_xxx will be created. But I don’t have it. Do I miss something? Is this normal since I don’t have any successful simulation?
