Report the results using:
OutputControl:Table:Style,
TabAndHTML; !- Column Separator
Output:Table:SummaryReports,
AllSummary; !- Report 1 Name
These are the inputs specific to outdoor air for the ZoneHVAC:IdealLoadsAirSystem. Enter the design specification outdoor air object name here and choose a name for the outdoor air node. You will also need to specify this node as an outdoor air node.
ZoneHVAC:IdealLoadsAirSystem,
YourDesignSpecName, !- Design Specification Outdoor Air Object Name
Outside Air Inlet Node 1, !- Outdoor Air Inlet Node Name
, !- Demand Controlled Ventilation Type
, !- Outdoor Air Economizer Type
OutdoorAir:Node,
Outside Air Inlet Node 1; !- Name
