You will have to troubleshoot this a little more to find out what is happening. Try adding these report variables and plotting the results to understand the results.
Output:Variable,*,Zone Thermostat Air Temperature,hourly;
Output:Variable,*,Zone Thermostat Heating Setpoint Temperature,hourly;
Output:Variable,*,Zone Thermostat Cooling Setpoint Temperature,hourly;
Output:Variable,*,Zone Predicted Sensible Load to Heating Setpoint Heat Transfer Rate,hourly;
Output:Variable,*,Zone Predicted Sensible Load to Cooling Setpoint Heat Transfer Rate,hourly;
If you are simulating zone sizing then the eio file will show you the design heating loads. You will also need winter and summer SizingPeriod:DesignDay objects to complete zone sizing.
SimulationControl,
Yes, !- Do Zone Sizing Calculation
No, !- Do System Sizing Calculation
No, !- Do Plant Sizing Calculation
Yes, !- Run Simulation for Sizing Periods
No; !- Run Simulation for Weather File Run Periods
