I'm assuming you are using EnergyPlus 8.2.0. If you are then the problem is almost certainly a bug found in the original 8.2.0 release. The bug was patched in Update 1, available here. OpenStudio 1.6.0 is designed to work with this patched version of EnergyPlus.
