here is some sample ruby code that you would use in a measure to create a sensor, an actuator and a program:
Sensor
Create an output variable for OATdb
output_var = "Site Outdoor Air Drybulb Temperature"
output_var_oat = OpenStudio::Model::OutputVariable.new(output_var, model)
Create a sensor to sense the outdoor air temperature
oat_sensor = OpenStudio::Model::EnergyManagementSystemSensor.new(model, output_var_oat)
oat_sensor_name = "OATdb Sensor"
oat_sensor.setName(oat_sensor_name)
Actuator
create a fan
always_on = model.alwaysOnDiscreteSchedule
fan = OpenStudio::Model::FanConstantVolume.new(model,always_on)
Create an actuator to set the fan pressure rise
fan_press = "Fan Pressure Rise"
fan_actuator = OpenStudio::Model::EnergyManagementSystemActuator.new(fan, "fan", fan_press)
fan_actuator.setName("#{fan.name} Press Actuator")
Programs
Create a program all at once
fan_program_1 = OpenStudio::Model::EnergyManagementSystemProgram.new(model)
fan_program_1.setName("#{fan.name} Pressure Rise Program by Line")
fan_program_1_body = <<-EMS
SET mult = #{oat_sensor.handle} / 15.0 !- This is nonsense
SET #{fan_actuator.handle} = 250 * mult !- More nonsense
EMS
fan_program_1.setBody(fan_program_1_body)
Create a second program line by line
fan_program_2 = OpenStudio::Model::EnergyManagementSystemProgram.new(model)
fan_program_2.setName("#{fan.name} Pressure Rise Program by Line")
fan_program_2.addLine("SET mult = #{oat_sensor.handle} / 15.0 !- This is nonsense")
fan_program_2.addLine("SET #{fan_actuator.handle} = 250 * mult !- More nonsense")
Create a third program from vector of lines
fan_program_3 = OpenStudio::Model::EnergyManagementSystemProgram.new(model)
fan_program_3.setName("#{fan.name} Pressure Rise Program by Vector of Lines")
fan_program_3_lines = []
fan_program_3_lines << "SET mult = #{oat_sensor.handle} / 15.0 !- This is nonsense"
fan_program_3_lines << "SET #{fan_actuator.handle} = 250 * mult !- More nonsense"
fan_program_3.setLines(fan_program_3_lines)
Actuatorcreate a fan
Programs
EMS
Sensor
Actuator
create a fan
Programs
EMS
Create a second third program line by linefrom a vector of lines
Sensor
Temperature" output_var_oat = OpenStudio::Model::OutputVariable.new(output_var, model)
output_var_oat)
Sensor" oat_sensor.setName(oat_sensor_name)
Actuator
create a fan
model.alwaysOnDiscreteSchedule fan = OpenStudio::Model::FanConstantVolume.new(model,always_on)
Rise"
fan_press) fan_actuator.setName("#{fan.name} Press Actuator")
Programs
Line")
<<-EMS
nonsense
EMS
nonsense EMS fan_program_1.setBody(fan_program_1_body)
Create a third program from a vector of lines
Line")
nonsense") fan_program_2.addLine("SET #{fan_actuator.handle} = 250 * mult !- More nonsense")
Lines")
nonsense"
nonsense" fan_program_3.setLines(fan_program_3_lines)
