You can use the API to do so, using SurfacePropertyOtherSideCoefficients.
Here's the second example from the I/O reference guide here
model = OpenStudio::Model::Model.new
sprop = OpenStudio::Model::SurfacePropertyOtherSideCoefficients.new(model)
sprop.setName("OSCCoef:Zn005:Wall004")
sprop.setCombinedConvectiveRadiativeFilmCoefficient(1.23)
sprop.constantTemperature
sprop.constantTemperatureCoefficient
sprop.setConstantTemperature(0)
sprop.setConstantTemperatureCoefficient(0)
sprop.setExternalDryBulbTemperatureCoefficient(1)
sprop.setGroundTemperatureCoefficient(0)
sprop.setZoneAirTemperatureCoefficient(0)
sprop.sinusoidalVariationofConstantTemperatureCoefficient
sprop.setSinusoidalVariationofConstantTemperatureCoefficient(false)
sprop.setPeriodofSinusoidalVariation(24)
sprop.previousOtherSideTemperatureCoefficient(0)
sprop.setPreviousOtherSideTemperatureCoefficient(0)
sprop.resetMinimumOtherSideTemperatureLimit
sprop.resetMaximumOtherSideTemperatureLimit
puts sprop
Out:
OS:SurfaceProperty:OtherSideCoefficients,
{0080fb86-3998-4681-ae5c-908610b02e6b}, !- Handle
OSCCoef:Zn005:Wall004, !- Name
1.23, !- Combined Convective/Radiative Film Coefficient {W/m2-K}
0, !- Constant Temperature {C}
0, !- Constant Temperature Coefficient
1, !- External Dry-Bulb Temperature Coefficient
0, !- Ground Temperature Coefficient
, !- Wind Speed Coefficient
0, !- Zone Air Temperature Coefficient
, !- Constant Temperature Schedule Name
No, !- Sinusoidal Variation of Constant Temperature Coefficient
24, !- Period of Sinusoidal Variation {hr}
0, !- Previous Other Side Temperature Coefficient
, !- Minimum Other Side Temperature Limit {C}
; !- Maximum Other Side Temperature Limit {C}
If s is an OpenStudio::Model::Surface, to set the property:
s.setSurfacePropertyOtherSideCoefficients(sprop)
puts sprop
Out:
OSCCoef:Zn005:Wall004, Surface Property Other Side Coefficients 2, !- Name
