You need to provide a minimal workflow (OSW) file since reporting Measures are tested in the context of simulation results. Documentation is available here. It can be as simple as just identifying your OSM, a weather file, and your reporting Measure. Good for you for creating a Measure test!
You need to provide a minimal workflow (OSW) file since reporting Measures are tested in the context of simulation results. file. Documentation is available here. It can be as simple as just identifying your OSM, a weather file, and your reporting Measure. Good for you for creating a Measure test!
