If you manually download measure files from the BCL website, you will need to save it in:
  • C:\Users\your_username\BCL on Windows machines
  • drive_name\Users\your_username\BCL on Mac machines
Besides manually downloading from the BCL website, you can also download measures from OpenStudio using the menu command Components & Measures / Find Measures (see below). I recommend the second option, since the measure files you download will automatically be placed in the correct directory.
Downloading BCL measures directly from OpenStudio
Somebody has asked a very similar question that you may want to reference as well.
