The eQuest interface enforces the DOE2.2 limits on various inputs. You can try using DIAGNOSTIC NO-LIMITS ..
But even that workaround is not enough for some inputs. @Daniel's comment about lowering the fan efficiency to achieve the desired fan kW is likely the best alternative.
