Try importing the IDF into the corresponding version of OpenStudio, which will retain most EnergyPlus objects except for HVAC (see this question for more details). Then:
Save the OSM file
Check all the Ideal Air Loads boxes on the Thermal Zones tab (or add the Enable Ideal Air Loads For All Zones measure on the Measures tab)
Run the OSM to generate the
out.idffrom OS, which can be found in the<osm folder>/run/#-EnergyPlusPreProcess-0
Save the OSM file
Check all the Ideal Air Loads boxes on the Thermal Zones tab (or addAdd the Enable Ideal Air Loads For All Zonesmeasure(or check all the boxes on theMeasures tab)Thermal Zones tab)Run the OSM to generate the
