I believe that most of the objects in EnergyPlus are actually related to HVAC so that is a lot of objects. Here is a list that can get you started at least. For many EnergyPlus objects the name is made up of pieces using colons to separate them. To shorten this list, a "wildcard" is used in the list below that indicates that all items which start with that name up to the first colon should be considered HVAC related objects.
  • AirConditioner:*
  • AirLoopHVAC
  • AirLoopHVAC:*
  • AirTerminal:*
  • AvailabilityManager:*
  • AvailabilityManagerAssignmentList
  • Boiler:*
  • Branch
  • BranchList
  • CentralHeatPumpSystem
  • Chiller:*
  • ChillerHeater:*
  • Coil:*
  • CoilPerformance:*
  • CoilSystem:*
  • CondenserEquipmentList
  • CondenserEquipmentOperationSchemes
  • CondenserLoop
  • Connector:*
  • ConnectorList
  • Controller:*
  • CoolingTower:*
  • CoolingTowerPerformance:*
  • Dehumidifier:*
  • DemandManager:*
  • DemandManagerAssignmentList
  • DesignSpecification:*
  • DistrictCooling
  • DistrictHeating
  • Duct
  • ElectricLoadCenter:*
  • EnergyManagementSystem:*
  • EvaporativeCooler:*
  • Fan:*
  • FanPerformance:*
  • FaultModel:*
  • FluidCooler:*
  • FluidProperties:*
  • Generator:*
  • GroundHeatExchanger:*
  • HVACTemplate:*
  • HeaderedPumps:*
  • HeatExchanger:*
  • HeatPump:*
  • Humidifier:*
  • HybridModel:*
  • LoadProfile:*
  • NodeList
  • OutdoorAir:*
  • Pipe:*
  • PipingSystem:*
  • PlantComponent:*
  • PlantEquipmentList
  • PlantEquipmentOperation:*
  • PlantLoop
  • Pump:*
  • Refrigeration:*
  • SetpointManager:*
  • Sizing:Parameters
  • TemperingValve
  • ThermalStorage:*
  • ThermostatSetpoint:*
  • UnitarySystemPerformance:*
  • WaterHeater:*
  • ZoneControl:*
  • ZoneHVAC:*
  • ZoneTerminalUnitList
You can see each individual name by looking at the Energy+.idd file.
