I suggest running a model with an air wall and a second run without. This will allow you see the relative impact of using the air wall assembly. My guess is that there would be more of an impact if you are using an airflow network than if you are not. Passive air circulation is going to be important to model in this small structure. It would be great to hear from somebody else about how well the air wall works in horizontal surfaces. Eric
