There is an add meter measure that has an argument for frequency.
Then another will make a flood plot much like ResultsViewer. You could change that to write out to a csv. Here is an example that writes out CSV as a guide.
Then another will make a flood plot much like ResultsViewer. You could change that to write out to a csv. Here There is an example that writes out CSV as a guide.
There Their is an add meter measure that has an argument for frequency.
Then another will make a flood plot much like ResultsViewer. You could change that to write a csv. There here is an example that writes out CSV as a guide.
