You can use an ZoneHVAC:IdealLoadsAirSystem for example, or the more convenient HVACTemplate:Zone:IdealLoadsAirSystem.
From the EMS Application guide for Ideal Loads Air System:
An actuator called “Ideal Loads Air System” is available with control types called “Air Mass Flow Rate” (supply air), “Outdoor Air Mass Flow Rate,” “Air Temperature,” and “Air Humidity Ratio.
