I suspect that you will need to add an ExternalInterface:FuctionalMockupExport:To:Schedule (Variable or Actuator). In other words you will need to add a least one input to EnergyPlus, even if you just feed a value of 0 the whole time.
I suspect that you will need to add an 'ExternalInterface:FuctionalMockupExport:To:Schedule(or variable or ExternalInterface:FuctionalMockupExport:To:Schedule (Variable Actuator). actuator)'. In other words you will need to add a least one input to EnergyPlus, even if you just feed a value of 0 the whole time.time.
