To build upon @mdahlhausen's answer in more specific terms, here's what I've been doing to automate this stuff:
- Create a spreadsheet with columns ["model_space_name", "watt", "hours"].
- You can have several lines that have the same "model_space_name", the space will then get multiple Lights objects.
- You could also include your multiplier here if you wanted to... In my spreadsheet I actually have more columns, for eg Fixture (eg 'Fluorescent Linear T8 590mm, 2-18 Watt, electronic ballast'), Count, W/fixture and I calculate "watt" by doing Count times W/fixture
- Use Roo to parse the Excel spreadsheet
- I find this convenient exactly because I have multiple columns and formulas and I don't need to export a CSV each time I change it.
- You could also just export your spreadsheet to CSV and use the built-in CSV module if you find this easier.
- Define a ScheduleRuset in my model to use as a default profile. That would be
SecondarySchool Bldg Lightin your example, let's call itlight_schgoing forward - Loop on parsed rows (from Excel),
- use
model.getSpaceByName(row["model_space_name"]).getto get the corresponding space, and create a new lighting object (you need to create aOpenStudio::Model::LightsDefinitionand aOpenStudio::Model::Lightsthat references it). - The real key point here is to scale to the
SecondarySchool Bldg Lightto get the correct number of hours while maintaining the same profile. For this, I leverage openstudio-standards' ScheduleRuleset.annual_equivalent_full_load_hrs. I store the initialeflh = light_sch.annual_equivalent_full_load_hrs. For the lighting objects, I clone this schedule, get the ScheduleDay attached to it (it helps if there's only one...) and scale each value entered accordingly by looping onday_sch.times.with_index(new_value = old_value * daily_h * 365 / eflh.to_f). - Neat trick: I rename the cloned schedule like
#{light_sch.name} - #{daily_h} hrs/day, so that in the loop I can test whether I already created it or not to avoid duplicating it many times unnecessarily.
- use
To build upon @mdahlhausen's answer in more specific terms, answer, here's what I've been doing to automate this stuff:doing:
"hours"]."hours"]. You can have several lines that have the same "model_space_name", the space will then get multiple Lightsobjects. - You could also include your multiplier here if you wanted to... In my spreadsheet I actually have more columns, for eg Fixture (eg 'Fluorescent Linear T8 590mm, 2-18 Watt, electronic ballast'), Count, W/fixture and I calculate "watt" by doing Count times W/fixture
SecondarySchool Bldg Light in your example, let's call it light_sch going forwardmodel.getSpaceByName(row["model_space_name"]).get to get the corresponding space, and create a new lighting object (you need to create a OpenStudio::Model::LightsDefinition and a OpenStudio::Model::Lights that references it).SecondarySchool Bldg Light to get the correct number of hours while maintaining the same profile. For this, I leverage openstudio-standards' ScheduleRuleset.annual_equivalent_full_load_hrs. I store the initial eflh = light_sch.annual_equivalent_full_load_hrs. For the lighting objects, I clone this schedule, get the ScheduleDay attached to it (it helps if there's only one...) and scale each value entered accordingly by looping on day_sch.times.with_index (new_value = old_value * daily_h * 365 / eflh.to_f). #{light_sch.name} - #{daily_h} hrs/day, so that in the loop I can test whether I already created it or not to avoid duplicating it many times unnecessarily.To build upon @mdahlhausen's answer, here's what I've been doing:
- Create a spreadsheet with columns ["model_space_name", "watt", "hours"]. You can have several lines that have the same "model_space_name", the space will then get multiple Lights objects.
- Use Roo to parse the Excel spreadsheet. You could also just export your spreadsheet to CSV and use the built-in CSV module.
SecondarySchool Bldg Lightin your example, let's call itlight_schgoing forward - Loop on parsed rows (from Excel), use
SecondarySchool Bldg Lightto get the correct number of hours while maintaining the same profile. For this, I leverage openstudio-standards' ScheduleRuleset.annual_equivalent_full_load_hrs. I store the initialeflh = light_sch.annual_equivalent_full_load_hrs. For the lighting objects, I clone this schedule, get the ScheduleDay attached to it (it helps if there's only one...) and scale each value entered accordingly by looping onday_sch.times (day_sch.times.with_indexnew_value = old_value * daily_h * 365 / eflh.to_f). Neat trick: I renameI renamed the cloned schedule like#{light_sch.name} - #{daily_h} hrs/day, so that in the loop I can test whether I already created it or not to avoid duplicating it many times unnecessarily.
To build upon @mdahlhausen's @mdahlausen's answer, here's what I've been doing:
SecondarySchool Bldg Lightto get the correct number of hours while maintaining the same profile. For this, I leverage openstudio-standards' ScheduleRuleset.annual_equivalent_full_load_hrs. I store the initialeflh = light_sch.annual_equivalent_full_load_hrs. For the lighting objects, I clone this schedule, get the ScheduleDay attached to it (it helps if there's only one...) and scale each value entered accordingly by looping on day_sch.times (new_value = old_value * daily_h * 365 / eflh.to_f). - I renamed the cloned schedule like
To build upon @mdahlausen's answer, here's what I've been doing:
#{light_sch.name} -, so that in the loop I can test whether I already created it or not to avoid duplicating it many times#{daily_h} hrs/day#{hours}unnecessarily.unecessarily.
canhave several lines that have the same"model_space_name", the space will then get multiple Lights objects."model_space_name" - Use Roo to parse the Excel spreadsheet. You could also just export your spreadsheet to CSV and use the built-in CSV module.
rows (from Excel),rows, usemodel.getSpaceByName(row["model_space_name"]).getto get the corresponding space, and create a new lighting object (you need to create aOpenStudio::Model::LightsDefinitionand aOpenStudio::Model::Lightsthat references it). - The real key point here is to scale to the
#{light_sch.name} - #{hours}, so that in the loop I can test whether I already created it or not to avoid duplicating it many times unecessarily.)
