Spaces inherit loads data from the Space Type definition. Once set load in space types, you cannot change them in the individual spaces interface.
On a practical level, adding individual lights to each space is incredibly time intensive. If you want exact room-by-room wattages, I would suggest removing lighting definitions from your spaces types and adding a single light object per room which sums the lighting power in that room, calculated from a spreadsheet. You can automate this by exporting the space name and total wattage to a .csv file, then using a custom OpenStudio measure to read the .csv, loop through your spaces, and add the light object with the given wattage.
Spaces inherit inherent loads data from the Space Type definition. Once set load in space types, you cannot change them in the individual spaces interface.
