Many people use EnergyPlus in Windows 10 so it is something specific about your computer.
If you are double clicking the "EnergyPlus.exe" file that is not how you start EnergyPlus. Try double clicking on EP-Launch instead.
If that is not the issue, it could be because of the permissions in the directory where you installed EnergyPlus. Right click on the directory and select "Properties" and then select "Security". If you don't have "modify", "read & execute", "read", "write" permissions, than you might need to install it in a directory that does have those permissions.
