Try drawing out all the floor plans and then move the second floor up above the 1st floor. Then use the create spaces from diagram on each floor plan. Then you will have to Intersect the whole model under the surface matching tool. I have noticed that the surface matching in side the sketchup plugin does not do a good job sometimes. There is a measure you can use inside of the openstudio app called SurfaceMatching. You can download that with the BCL Website. This one does a better job at matching. Good Luck
