If you have created your water-cooled VRF system correctly by setting the AirConditioner:VariableRefrigerantFlow object's Condenser Type input field set to WaterCooled, and created a PlantLoop object to represent the domestic hot water system using the rejected heat, then you should be able to generate an output variable named VRF Heat Pump Condenser Heat Transfer Rate. This should add a column to your output CSV file to show the Watts of heat transfer that occurs between the refrigerant and the condenser water loop (in this case, your domestic hot water system).
