The results tab works all of the sudden. My initial thought was that it was a Windows update, but it turns out, I can only access the results tab when I open the OpenStudio application through the Sketchup plugin. When I try to open the model directly in OpenStudio, the results tab does not work.
The results tab works all of the sudden. A Windows update appears to have fixed it. My initial thought was that it was a computer has had some Windows update, updates and Flash updates in the last few weeks, but it turns out, I am not sure exactly which one did the trick. The only recommendation I can only access provide to someone else having the results tab when I open the OpenStudio application through the Sketchup plugin. When I try same issue is to open the model directly in OpenStudio, the results tab does not work.make sure Windows is up to date.
