That measure can be used in the apply measure now button in OS or in PAT. For LEED purpose, you would want to run that measure in PAT to create the runs for 90, 180, and 270 degree rotation: image description
What do you mean by "put the measure"? How are you applying the measure, in OS or in PAT? Are you making sure that you input a value for the roatation? image description
Also, is your model running before you apply the script?
