@Amir Roth, I am trying to use the Cloud, I have access to input my files, but I have not been able to run the simulation successfully. I always get the error:
Program Version,EnergyPlus, Version 8.2.0, YMD=2015.01.16 13:10,IDD_Version 8.2.0
* Severe
* IP: IDF line~146133 Did not find "10HeatBalanceAlgorithm" in list of Objects
* Severe * IP: Possible incorrect IDD File
* ~~~ * IDD Version:"IDD_Version 8.2.0"
* ~~~ * Version in IDF="8.2" not the same as expected="8.2"
* ~~~ * Possible Invalid Numerics or other problems
* Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination.
...Summary of Errors that led to program termination:
..... Reference severe error count=2
..... Last severe error=IP: Possible incorrect IDD File
*** Warning: Node connection errors not checked - most system input has not been read (see previous warning).
*** Fatal error -- final processing. Program exited before simulations began. See previous error messages.
*** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
*** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors.
*** EnergyPlus Terminated--Fatal Error Detected. 0 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 1.29sec
Have you try to use the cloud? or do you have any procedure to use the IDF file generated for OS?
@Amir Roth, Rothm, I am trying to use the Cloud, I have access to input my files, but I have not been able to run the simulation successfully. I always get the error:
* Severe
